hi all nose weight tail weight is going to depend on where you fit all your gear the balance point is not going to move it's 330 mm
from the leading edge of the wing next to the fuse as I said it all depends on gear placement. example move the turbine rearward
on the mount you need more weight forward
regards
ken
kingtech turbines oz
