If I am reading your post correct, the tube is your spar/strength, and the pins simply align everything when you epoxy the stabs on...
I personally built an internal push rod to work the tail wheel.
There are a couple long threads on this plane if you search for it. It builds heavier than the box suggests, but flies great anyhow.
