Originally Posted by
TonyF
I have just finished an assembly thread on my new H-9 P-7. I did a lot of modifying and updating that has worked out very well. It is in RCGroups in the Classic pattern forum. Hope it helps!
In all types of pattern flying, there are two key elements- aircraft set up and consistent flying. Go check out Tony's thread. I have seen this airplane in person and it sets a benchmark for classic pattern set up. One thing that I have learned over the past year is that I didn't know as much as I thought I did. When you have a true master paying it forward, take advantage of the opportunity and learn everything you can. The difference between a well set up airplane is like the difference between skittles and lobster for dinner.
-Robert
Edit- I have flow Tony's airplane and I can verify that this setup is worth the effort. It is the best tracking and easiest handling classic that I have flown to date. It is so easy to make it look good when you are not wasting effort fighting the aircraft!
