It is setup for either the Dave Brown on Sullivan since the lower engine bolts are closer together and not a square pattern like a Gator or Dubro mount.
So in the heck do you know how tight to tighten the rubber? YOu can put but so much grunt on the bolt or the rubber will tear, yes?
I have only ever used Gator or Hyde mounts.
