Using the miniature pipe cutter is very handy and also leaves a bevel around the
outside of the pipe which is good to avoid damaging the silicon water pipe when
slipping it over. The Du-Bro pipe bender is also a must to achieve a good bend
ensuring good flow.
I like to mount the water pipes against the side of the housing for added strength.
A good 'block' of epoxy is used to mount them in place to be 100% water tight.
I use a single inlet - outlet water cooling system - Inlet on the left and outlet on
the right - flowing to the ESC - then to the motor. Protrusion at least 10mm en-
suring good pick up.
Servo tray /mount - holes drilled to add extra bonding strength - I have had the
mount pop lose once or twice from a big air landing.
