Fitting the steering push rod guide tube: also tucked against the side wall of the
housing for strength - out of the way - brass tube with a plastic tube within.
Epoxied in place as with the water cooling pipes - coated with coloured gel coat.
Board ready for a final fine sand - before two clear coats of resin to be applied for
a high gloss finish.
