John,
With out any gauges how did you determine the spring size/tension you are using in the robart cylinder?? I have a UMS system coming and plan on setting up a gear test on my bench but I would like to add the accumulater to the system. Where did you get the xicoy pump?? would a jetcat fuel pump work too??
Vin...
