BTW: You may want to measure the BEC current while putting a LOAD on the servos.
In other words restrict the movement a bit of at least two control surfaces as you move all of the servos at once.
That gives you a more realistic worst case.
Standard high torque servos can draw as much as 2 amps each, particularly the digital ones.
