Originally Posted by
jimbow412
Maybe I was not clear- Neither servo moves when hooked to Y harness for flaps. However If I plug each servo into receiver they work??
Sounds like a faulty Y connector, assumeing you are useing the same channel to test the servo & the Y . If the servo works in the same channel that you plug the Y into & then it stops working, i'd say replace the Y connector, because the Y is really just a servo extension putting the two servos in paralell......Gene
