I would get a dx6 then figure out the plane. VERY few of the micro bnf planes fly well without a little exponential.. I could fly my micro t28 inverted 5" of the ground with a bit of expo. With the stock transmitter it was too docile on low rate and too spastic on high... Get a decent transmitter. Also a trick on the little pos transmitters. Glue on a 1-2 inch extension onto the stick. Longer stick equals more thumb movement for the same control deflection makes it a bit less spastic if you jack up the throws. A scrap of the right sized brass tubing works good....
