Originally Posted by
gene6029
Your right Tom. I missed that part. Your correct, the problem is elsewhere.....Gene
That's OK. I seem to have missed the part where the OP says that one servo will work, using the flap channel, but not two, on a Y-harness. But, if I read it correctly, the same Y-harness works when everything is plugged into a different channel.
Thinking about it, I'd try a different receiver, just to see what happens.
