RCU Forums - View Single Post - Is West System a Polyester Epoxy?
Old 02-23-2014 | 10:42 AM
Corsair2013's Avatar
Corsair2013
I have a Skyshark P-40 Fiberglass Fuselage. I don't know what type of resin was used to construct and one of the guys said he called Skyshark and they said the fuselage was made with Polyester Resin.
I was trying to figure out if the 5 minute and 30 minute LHS epoxy was okay to use on the fiberglass since I am almost finished. I did sand the fiberglass prior to application of any epoxy. I also used hot glue in some areas but didn't sand.
I was going to lay up a little more fiberglass inside to strengthen some areas using the WEST SYSTEM so again will this be okay to us as long as I sand/rough up the area first?
Thanks again
Keith
