RCU Forums - View Single Post - Need 4 x 100(+) Watt LiFe Capable Charger Suggestion
Old 02-24-2014 | 10:54 AM
JKEpps's Avatar
JKEpps
Default Need 4 x 100(+) Watt LiFe Capable Charger Suggestion
Hello all,
I'm trying to find a 4 port charger that can output 100 watts or more per port. I'm currently using the Vista Power Quadplay Multi Charger Q6AC. Up until now it's been fine for my batteries as I've only used smaller packs. Now as I've moved more towards electics, .40 size or better, I'm using A123 2600mAh batteries in a 6s (20V) formation. The Vista will charge them just fine, but at 1C which maxes the charger out at 2.5/2.6 amps per port or 50watts.
In bench runs, I'm taking apx 2000mAh out of the battery, so to recharge it takes like 45 mins per pack. I'd like to charge at 2C or 3C or higher, which would mean I need 20V x 5Amps = 100Watts, or 20V x 7.5Amps = 150 per port, or better. I like the versatility of 4 ports, so I can charge other batteries too. Is there such an animal out there? If I have to bridge two of the ports, that would work too, but it's not preferrable. If no such animal exists, can anyone recommend a 2 port LiFe capable charger of 6s @ 100+ watts per channel or better?
An extreme wish list would be for a 10s capable charger.
Thanks in advance.
-Jorden
