RCU Forums - View Single Post - YS 61AR Issue
Thread: YS 61AR Issue
Old 02-24-2014 | 12:45 PM
Dean Pappas
Hello Jeff,
If and only if this happens only after the engine has thoroughly warmed up, then you are probably looking at a worn-out piston/liner.
The first sign of a worn top end is a rich transition and sporadic quitting rich. Why? Combustion blow-by puts way too much pressure into the fuel sstem and this is beyond the range of the regulator to deal with.
Regards,
Dean Pappas
