Originally Posted by
600Bob
You don't have to run a second battery and switch for the ignition.
True, there is a device called an IBEC that will power the ignition off the RX and you will be able to switch the ignition off via your TX. I agree that finding a place for the ignition module could be an issue. IMO Gas just isn't a good way to go until you get 30cc or larger.
