Originally Posted by
stlmstr
I have the control surfaces set to max values but I still have a problem. On both the elevator and rudder I am getting much more travel on one side compared to the other. The up elevator is about 1/2 less travel than the down elevator and the left rudder is twice as much as right rudder. I only know how to change the overall travel through the TX but don't know how to increase up elevator without changing down elevator and the same thing for the rudder. How do I get them even? The link points on the servo arms and horns are about as good as I know how to get them although the control rod for the Rudder is too short so I can just barely get it screwed down where it want slip out. Help!!
lets use the elevator as an example... get to the menu where you're able to change the elevator throw, then hold the elevator stick UP and while holding the stick, adjust the travel value.
then hold the elevator stick DOWN and adjust. (it's the same for all switches and flight controls, to set BOTH end points or travel amounts, hold the respective stick in the direction you're looking to change)
there should be a little arrow next to the word 'Elev' or 'Rudd' that displays which stick position is currently being adjusted.
you also may need to zero out any sub trim, and there is also a 'differential' setting which may be causing some grief.
you MAY want to either start with an empty / default setting airplane and start from scratch, rather than going through each and every menu and making sure the settings are at zero.
hope that makes sense.
