RCU Forums - View Single Post - setting up flaps on a AR6210 Receiver
Old 02-25-2014 | 07:14 AM
AMA 74894's Avatar
AMA 74894
Moderator
one other point that will probably fix the rudder pushrod, after you've set the endpoints (the servo travel and subtrim) you'll very likely need to mechanically re-adjust all the flight controls...
Sub trim will cause the servo to center in a different spot, and I'd bet the rudder pushrod will miraculously 'grow' to a more correct length.
if it doesn't, is it possible the rudder servo is installed backwards? (backwards specific to this model, there isn't a rule of thumb with the servo's control horn further away from the rudder rather than closer to the rudder)
