Larry,
When I put my hinges in I made sure the flap/aileron were connected at the time to keep them from slipping. I also made sure they were connected to the ribs in some way.
BTW, it looks like your tubing is to close to where the wheel will fit in the wheel well. Say that 3 times fast. I put mine against the spar. Be sure to double check this.
Looking good. Keep the pix's coming.
Thanks Steve and Hircflyer. I really did not notice the panel lines before. Maybe because I knew it would add to the detail time.
Larry if you decide not to include the panel lines I will understand. It still looks good with just the rivets.
Boyd.
