RCU Forums - View Single Post - Wren 160 failures
Old 02-26-2014 | 06:45 AM
  #43
jacojet
Originally Posted by afioretti
I looked at the pics and speculated that there could be an intake issue. I work on turbines and there is a lot of data here especially in the pics to suggest possible intake issues. I don't see much to suggest it is not. I asked what the diamater of the wheel is. I would also like to know what the depth of the throat is because it looks shallow but I doubt anyone will reply with dimensions. As for the Wren 160 CNC compressor wheel, I had one show up on a nexus (simjet). I dont see simjets blowing comp wheels... The intake is substatially deeper on those so I would start in the area of the intake. It makes the most sense.
A. Fioretti
I will measure when I get my hands on one that is stripped, I have checked one that belongs to a friend (who BTW is not using it for fear of it failing) and what I can say is that the top of the compressor is about 55 mm and the bottom about 74-75 mm, the throat is about 7 mm deep, measured from the edge to the top of the compressor blades. Maybe we will use this one as a experiment to see if the modified intake will work. Just need to convince my friend!
