RCU Forums - View Single Post - KV-1 & Jadgpanther full option problems
Old 02-27-2014 | 05:27 AM
Strato50's Avatar
Strato50
Using the reclocked holes works very well. Just remember there is a limit to how far they will go; if you go too far when the spring coils up it will jam against the suspension arm and it will get stuck..!
Don't ask how I know...
Also you can experiment with clocking the first and last suspension only so that the middle wheels move more with uneven ground, while the front & rear hold more weight. You might notice the tank drives better
