RCU Forums - View Single Post - Will aluminum fuselage interfere with electronics
Old 03-02-2014 | 08:43 AM
acerc's Avatar
acerc
Originally Posted by BMatthews
Acerc, any chance of some pictures of how you arranged your antenna on these models? I'm sure Kent and others would like to see what worked out well for you.
I am assuming you are asking if the antenna was external of the airframe. No, it was not, it is totally encased within the airframe dead center of all that aluminum. I have enclosed a pic of my small Pitts, from the rear of the cockpit forward is aluminum sheeted and the Rx is center of the cabanes. I am currently building a $8500 Pitts and it will be the same. I personally have no doubt the signal has no issue with aluminum. Carbon fiber is a different story!!!
acerc is offline
