RCU Forums - View Single Post - Will aluminum fuselage interfere with electronics
Old 03-02-2014 | 12:33 PM
acerc's Avatar
acerc
Ok, fine, here! The aluminum (partially) covered plane in the aluminum trailer and then with three aluminum sheds in between. A bit generic in videography but shows the results just the same!
( Whoops! )
If this isn't enough then you'all are on your own....
acerc is offline
