http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFLM4032A
This is probably a better choice at only 770Kv.
This might work well with 13x4 on 4s?... keeps you at right on the rated 42A max. according to MotoCalc.... and keeps the 200g motor at 3W/g!
Motor: E-Flite Power 32 Outrunner 770KV; 770rpm/V; 2.4A no-load; 0.02 Ohms.
Battery: Thunder Power TP4400 (G4 ProPower 45C) (45C); 4 cells; 4400mAh @ 3.7V; 0.002 Ohms/cell.
Speed Control: Castle Creations Phoenix 60; 0.0012 Ohms; High rate.
Drive System: Direct; 13x4 (Pconst=1.17; Tconst=1) direct drive.
Airframe: Anything you want.
Motor Amps = 42.2
Motor Volts = 14.4
Input (W) = 608.1
Prop RPM = 10203
Thrust (oz) = 103.5
PSpd (mph) = 38.7
