Originally Posted by
Jannica
A friend of mine is giving up on waiting for the Wea Tx and has ordered a Jeti system. I feel a little tempted myself but then I already have a whole bunch of Wea Rx and they are not bad in any way either. So, is there any way to combine the Wea and Jeti systems known to man? Is there any Wea module to put into a Jeti Tx to make it handle Wea RX or anything along that line? I guess no..but what´s wrong with asking?
Jannica
I considered this too but, I don't think it can be done. Although the Jeti has an internal PPM output jack that might be able to be utilized, the transmitter itself uses a single cell 3.6v lipo. The Weatronic transmitter modules require 5v-10v according to their specs so, even if you could get the PPM signal from the transmitter, you would require an external battery to power the module.
It is becoming very difficult to find a Tx to work with a Wea module. I just aquired a (discontinued) NIB Futaba 12FG to use as it seems like the Wea BAT 60 is seriously delayed. The 12FG is a step down in quality compared to the JR12xMV that I've been using but, I had become frustrated with the 8 channel limit that the JR12x/ Wea combo has. The Futaba 12FG with the Wea FASST adapter should give me 12 channels but unfortunately, it doesn't work! Intermittent glitching of the servos.
Mike
