RCU Forums - View Single Post - Weatronic 2.4 RF diagnostic tool
Old 03-07-2014 | 10:53 PM
  #2174
olnico's Avatar
olnico
Originally Posted by luv2flyrc
I considered this too but, I don't think it can be done. Although the Jeti has an internal PPM output jack that might be able to be utilized, the transmitter itself uses a single cell 3.6v lipo. The Weatronic transmitter modules require 5v-10v according to their specs so, even if you could get the PPM signal from the transmitter, you would require an external battery to power the module.
It is becoming very difficult to find a Tx to work with a Wea module. I just aquired a (discontinued) NIB Futaba 12FG to use as it seems like the Wea BAT 60 is seriously delayed. The 12FG is a step down in quality compared to the JR12xMV that I've been using but, I had become frustrated with the 8 channel limit that the JR12x/ Wea combo has. The Futaba 12FG with the Wea FASST adapter should give me 12 channels but unfortunately, it doesn't work! Intermittent glitching of the servos.
Mike
Mike, if you purchased this Tx specifically for this use, I would recommend you to call Jens in Germany. Check with him if it would be worth for you to send the transmitter + module over to them to see if that can glitching problem can be fixed.
