RCU Forums - View Single Post - A Ringmaster Bi-Plane
Old 03-08-2014 | 02:58 PM
  #141
flyingagin's Avatar
flyingagin
Took a break from the little bit of pack I can do (moving).
Worked on the wing tips, making them lighter by hollowing them out.
I not about to dig them out even with a ball mill in my Dremel. So I bored them out. I used the chucks from when I rough cut the tip blocks out to help the tips vertical and avoid pressure in one spot when clamped up in my drill vice.
I then chucked a Fostner style drill bit up in my drill press. I set the depth stop lock to leave me about 3/4" from the end. I then drilled a series of close spaced holes.
There is plenty of non-drilled stock at the end to carve it round. Then I will smooth out the inside a bit, and take the inside closer to the end of the tips.
It is already a heck of a lot lighter.
Ken
ID:	1976202   Click image for larger version
ID:	1976203   Click image for larger version
