Hy Guys,
Needs your comments, I just got a Craftsman blower, the engine is a 32, it's a rear induction engine with the muffler towards the shaft side. The engine would not start I noticed that it needed a new gas line, carb kit, and a carb to manifold gasket. I went ahead and replaced the worn out parts. I also noticed that the carb has only one screw for mixture adjustment. The other screw regulates the detent for the buterfly.
Is the mixture screw for hi speed mixture? How is the low end mixture controlled. The carb is a Walbro.
Is this engine easy to convert? Please help.
