Originally Posted by
Art ARRO
John,
My statement on the use of the HS speed brake/air brake in turns stems from Steve Elias' suggestion several years ago. As per his advice I plaqn to actuate the brake from a servo linked to the left slider on the tranny. Steve recommendation was NOT to deploy it during turns. Anyone's direct experience on this would be appreciated. Thanks.
Rgds,
Art ARRO
I usually deploy mine right before the turn on final, not during the turn, but that's just because I find it easier to flip the switch while the plane is flying straight.
Once you have the brake out you need to keep the plane up by raising the throttle a little, or it will fall out of the sky pretty quickly
