RCU Forums - View Single Post - Which type of engine mount bolts are the strongest?
Old 03-10-2014 | 06:43 AM
JPMacG
Bolts come in different strengths. The bolts sold for hobby use are probably the weakest, cheapest grade. You can get high strength bolts from an industrial supplier like McMaster Carr. They will be considerably more expensive. High strength bolts are available in both steel and stainless steel. Steel is less expensive.
