Originally Posted by
Mr Cox
The engine might not be totally bad, the design was similar to the .07GP, another heavy engine from them without much power in its stock form. With honest and correct marketing they could have found some usage though, I think, as easy handling quiet running engines.
I think you're right about that, Mr. Cox. I heard from another that the engine was quite good as a sport engine, and would turn larger props with ease. Mated up with the right airframe and prop, probably would have been a really nice performer. There are a few bad engines out there. But I think a lot of times modelers might be expecting more out of an engine, not understanding the mechanics of the situation. An engine in a marginal application with the wrong prop will more than spell problems.
Case in point, not long ago I tried a 7x3 prop on an Enya .09-III TV on a sport plane. It flew very .049 like. Someone unfamiliar would conclude the engine was a poor performer. I switched to a Top Flite 7x6 wood, it became a totally different airplane with very good airspeed. Problem with the 7x3 is that I was outside the Enya's power curve. That engine has high torque and maximum horsepower at a lower RPM than the modern Schneurles. Then the engine's heavier weight redeemed itself by its strong running characteristics on a different prop.
I think it may be the issue with the TT GP-18. WIth the right prop might make that engine a really sweet performer on the right airplane.
