RCU Forums - View Single Post - HL Tiger 1 wiring problem.......need help!
Old 03-10-2014 | 07:41 PM
  #44
YHR's Avatar
YHR
OK < just to be sure lets go over the servo cable set up.
DBC Receiver
THR CH 2
STR CH 1
TUR CH 4
GUN CH 3
This is the basic set up for a DBC. When you add the TBS you pass the throttle( CH 2) from the receiver into Prop 1 of the Benedini TBS. The second Prop one then goes from the TBS back to DBC THR. IN essence you are inserting the Benedini TBS between the receiver and the DBC3. Prop 3 on the TBS gets hooked to the output pins on the DBC3. This connection is the TBS encoder and sends all the sound triggers for battle sounds and other tank sounds.
