No change, removed both pins, one at a time.
When I remove the rear pin and push the boom towards the fuse, it just transfers to the other side?
Only cure I can see, is put a shim/filler plate between the boom and fuse.
Or, a different stab with the mounting holes closer together?
Maybe Alan will have an answer?
