[ATTACH]1977350[/IMG]
Here's the wing root profile. Keep in mind that this is traced at an angle, if you want to use this as a template to make wings you need to have it at the original angle of the wing root. Should work if you print this on A3 size paper.
Carlos, i measured the washout on my wing, it's 3 degrees!
Regards, Bart.
