Not enough water in the air in the jug to worry about. But if your cap is loose then it is exposed to moisture outside of the jug. If you keep your jug capped you will get most of your moisture from pumping fuel back in the jug from your tank, which gets moisture from the exhaust gas from the muffler pressure line.
