Originally Posted by
TooManySecrets
I think its possible to convert
this to
this. Id like some input on this but i think it should be possible. Maybe by changing the part where the flywheel is and the normal head to a watercooled one. Id like some input before i start ordering parts to convert it.
Thx guys.
It would cost twice as much as just buying the G260PUM in the first place.
You need every part of the G260PUM to make a RC engine into a small flywheel water cooled engine. About the only thing that is the same is the piston, ring, wrist pin and bearing.
You would need new cases, crank, flywheel, pullstart, cylinder, water cap, the two coils. That would easily total well over the $220 that a new G260PUM costs.
You could get a new G300PUM for about the same money also.
