set both needles to 1-3/4 turns out this will give you a rich condition,ruff running.turn the low in till the engine wants to hesitate when opening the throttle.then open it till it will just transition.
then go to WOT and turn in the high for peak rpm's.then you may have to go back and re-set low.but this setting should be flyable then fine tune it after flying.
