RCU Forums - View Single Post - Need Help with set-up.
Old 03-15-2014 | 11:07 AM
molokaiboy
Well I am not familiar with your radio, but I can give some advice. You need to adjust the pitch curves in your tx, lower half of the curve is for negative pitch and the upper half is positive. The heli mechanics will also ned to be set up correctly for the TX to do its job correctly as well.
Best bet is to try and find someone local to help you.
Les
