Yes this is the correct valve. They come with 4mm fittings built in and do not appear to have leak problems. I saw your photos on the F15 thread. Looking good. You will be pleased with the results when you have it operating. If you look for nylon tube 4 mm dia you should find a supplier. You will need to check the specs but you should find it will be adequate. Good luck!
john
