[QUOTE=Ernie Misner;11760766]
Originally Posted by
Broken Wings
Dubb Jett over at
http://jettengineering.com/ will hook you up.... It's fun when your Draggy Old Stik airframe with tricycle landing gear goes around a plane with retracts.....Made in the USA as well.....
Sport-Jett ".61 Size" Big Block Features
Broken Wings, what type of engine mount is that on your Jett? Fantastic looking stick, engine,.... and wheels!!!.....
It's a factory Jett radial mount that Dubb makes The black "spacer" is just a piece of black delrin that I drilled/c-sunk to mount up to the factory ARF holes in the fuselage. It also has a hole drilled vertical for the fults dual strut nose gear.
It works pretty well, you can remove the whole front end from the fuselage with four bolts. I'd tear the landing gear out and swap fuselages during the week and be out at the field ready to go by the next weekend.....
The wheels are Top Flite for the Elder.
Stiks are great model airplanes...
