RCU Forums - View Single Post - New to jets and needing some help
Old 03-17-2014 | 04:55 PM
Justflying1
Hello and welcome.
I think you have picked a perfect jet to start with and you should have many enjoyable flights. Installing the turbine I would suggest you read the instructions as they are pretty easy to understand. However you should also follow any specific regulation installation as well. For instance we in Australia must also fit a kill switch incase the ECU fails just to name one. I'm sure it will also be easier on someone to help you if you mention the turbine you are installing and the specific questions you are after. Going to the jet meets you will find lots of people who can lend a hand and answer your questions.
