RCU Forums - View Single Post - Programming 6 servo plane with 9C
Old 10-02-2003 | 11:10 AM
davensocal
Default Programming 6 servo plane with 9C
I have a 4 servo wing, 1 servo per aileron (x 2 ailerons), and 1 servo per flap (x 2 flaps).
I would like to setup the following features..
Full span ailerons
snap flap- switch enabled
crow - adjusted by VR-D, and switch enabled
Camber/reflex - on VR-E, and switch enabled
(also, it's a 2 servo V-tail, but that should be a seperate mix..)
Any ideas how to pull this off? What model type should I try? (I am ready to try Heli modes!) I tried the standard setups from the web page, and they didn't help any. I also tried mixing it myself, and I almost got it.. Problem was that the rest of the Crow was out of whack, when I tried to slave it off of the VR-D or the flap, the center positions would get hosed on the ailerons and tail.
