In the frame of our cooperation with Carsten, we'd like to announce the development of a new line of sensors.
The first of them will be the pressure sensor, which is specifically designed to send a telemetry feedback on the pressure available in your pneumatic tank.
The sensor board is quite small ( about 1 square inch ) and will feature a barbed fitting that allow the use of our top quality 100% USA manufactured pneumatic line:
http://www.ultimate-jets.net/collect...pneumatic-line
Up to 4 devices can be chained on the Futaba SBUS system ( port 1 to 4 ).
The devices can also be used in conjunction with the ASSI board by being plugged on the CAN bus.
If you do not have Futaba telemetry or an ASSI board, you can also use these sensors in conjunction with our CAN LCD device and get the pressure readout from inside the plane on the beautifully crisp color LCD screen.
We will come with other sensor boards in the future: proximity sensor, angular sensor, AOA sensor...
