Originally Posted by
acdii
The SIG kit has a piece of balsa that glues in from the last former to the rear of the fin, but not enough detail or description to get it right. The picture helps a lot. It tapers towards the tail and is flush, and not curved like the plans suggest. Now I see exactly how it needs to be done. Thanks
Oh, those pieces (right & left) just continues at the same angle as the last former, and tapers back to nothing, or as thin as you can get it with out sanding through it.
In other words, those filler pieces just continue at the same angle as the last former; and then follow the same angle as the upper out side corners... so when you put a straight edge on either the fuse side or upper outer corner, the lines continue through the filler pieces.
John M,
