RE: BME 50
rcPilotJAE: Thanks! I really appreciate your help! As far as the engine ignition upgrade on the wires, did you get your's from CH. Is it a big deal to change out the wires & plug cap?
Separate question about hinges---did you use CA hinges or another kind? I think if I cut 1 1/2" hinges for the elev/rudder that should work----your thoughts?
JC[:-]
