I would think with the GMP cub, the center line would be referenced through the horizontal stab at level flight with the correct CG; whether the center line will follow through the motor shalt is unknown due to possible motor down thrust / placement.... I checked my Sig plans and the engine shaft center line is well below the center line of the horizontal stab, so assume the center line is offset.
John M,
