Originally Posted by
daveopam
"Are you sure it's not rf coming down the metal pushrod? Are you on 2.4
A nyrod will stop vibrations as well so I would use that."
I may push my luck a little and change to Nyrod before changing the servo. (not advising anyone else to do the same) This should tell me if it is vibration or RF noise. If I still have issues than I would assume the servo is bad from being vibrated. If this cures the problem then it's most likely it was RF noise.
David
If you keep it above the strip in a safe dead stick landing area that would be a great test.
PS you already know this, but test with lots of height.
