Originally Posted by
Boormans
Yep tried this the electric engines still run at 3000 rpm apart . The only way I thought was to use the transmitter and master and slave channels futaba T8 fg but my set up must be wrong still hoping someone can tell me how to set the transmitter up
If you are using a Y connector try cutting the Red wire to one ESC ( it doesn't matter which one) if have not already done so. That way only one determines the speed of both motors. They should be within 20 RPM of one another, electrics are way easier to sync than glow engines ever were.
