RCU Forums - View Single Post - Hellcat Build with 250cc Radial
Thread
03-23-2014, 08:16 AM
152
flyn2high
My Feedback: (
2
1 Post
On the belly pan I choose to attach it to the center section with six 4-40 machine screws. I made light ply brackets with a 4-40 t-nut in each and attached it to the inside of the belly pan. After fitting and sanding the brackets so that they aligned with the center section I was ready to glue them in place. I knew that each bracket was nearly touching the center section when the belly pan was in place. I applied a liberal amount of Hisol epoxy to the surface of the bracket where it would come in contact with the wing center section. I paced the belly pan on the center section with all the brackets screwed in place and let the glue cure. I had only to remove the six 4-40 screws to remove the belly pan. The bracket were permanently glued to the center section
Reply
Like
flyn2high
View Public Profile
Send a private message to flyn2high
Find More Posts by flyn2high
View iTrader Profile
