RCU Forums - View Single Post - Bypass problem.
Thread: Bypass problem.
Old 03-24-2014 | 01:58 AM
Springbok Flyer's Avatar
Springbok Flyer
Originally Posted by Turbotronic
Jan,
If the inlet ducting is too small in cross section area it may remain an issue.
Andre
Andre,
The inlet is about 4.5 times the size of the turbine inlet, what would you consider enough intake area?
I will actually measure my other two installations to compare the exact turbine outlet to bell mouth distance. All the installations use the same turbine and bypass/ bell mouth ducting. So the inlet and outlet side of the bypass is also a constant.
Thanks for your help.
Jan
