Originally Posted by
AndyAndrews
You are saying that more than one engine does the same thing in the Jet? You can also run it without the top of the bypass. This will give it more airflow. I would be ready with a fire extinguisher if you do that though in case it catches fire again.
Sorry Andy, I was editing at the same time as your post. Yes, as per my original post - it has happened with two different engines (both being the same brand and model).
Jan
